- Jun 20, 2007
I have very limited space in my one car garage which is my workshop. Since I have a bad back everything in my shop is pretty much on wheels. This allows me to utilize space and I can also roll it around to clean and outside on a good day for better light.
I have been building a forge stand and will post some more pics when I get it finished. For right now here is a pic of the frame which should allow for you all to see what I am talking about.
(click thumbnail for larger view)
This is a pic of the cart looking from front to back. In the front there is a raised portion that this forge will sit on.
Since this cart is unfinished you will have to envision the finished cart somewhat. It will be pretty much wrapped in sheet metal to make the different sections divided.
In the lower back portion of the cart on will be a place for two propane bottles that will be used to power the forge, as can be seen by the rings welded in for the bottom of the bottles.
Directly in front of the propane bottles will be a wall that divides the lower back portion of the cart, where the gas bottles will sit and the lower front portion . The lower front portion will house a fire extinguisher and the rest of that area in the lower front portion will be divided into sections to store different steels.
The area directly under the tower (front upper area) will be utilized for PID controller and a few other bells and whistles. However there should still be enough room in this area to allow for my hammers and tongs to lie on a shelf created by the top of the lower front portion .
Now here is where the kicker comes in! I am also in the process of finishing a KMG clone and the area above the tanks could be used for this to sit on. That would allow great use of space and allow me a way to move the grinder outside on good days. The eyes arent' as good as they once were for fine work and the extra light comes in handy some days! The finished grinder and motor are pretty heavy just to pick up and move, plus I would need a stand to sit it on outside.
The area of my cart where the gas bottles sit would be basically divided off totally between the grinder and the bottles.
However with a gas leak does that really doesn't matter?
I guess the real question becomes how dangerous is it too have a propane bottle in the same room with a grinder throwing sparks?
Are the sparks from a grinder enough to ignite a propane leak?
How safe is a propane system once hooked up and checked for leaks?
If there is a leak anywhere in the propane hookup and whether you are sitting on top of it or not the gas is still can and will flow into the vicinity of the spark when you are in the same room!
So if this is potentially a problem! How do some of you explain that when I see pics of a lot of shops I see propane bottles setting around in the general vicinity of the grinders, or at least in the same room!
Anyone got any constructive advice about propane tanks in the shop! I would love to utilize that space but don't want to make a potential bomb in the process.
