- Aug 9, 2021
Indiana Knives EDZ: My first Vanax blade. Judging from Larrin's ratings, Vanax is the second best all-around steel, after Magnacut. Here are BESS scores at five spots spaced along the blade from near the tip to near the heel:
133 187 194 170 177
Secondary bevel angles are 20 and 22 degrees. Very little convexity. Primary angles are about 2.5 degrees. Full flat grind. Blade thickness looks like a smidge over 1/10 inch. The choil works for me as a finger choil, but it might not if you have large fingers.
Great action. The hole is about 95% as good as a Spydie hole. I can flick it open with thumb, forefinger, or middle finger. Solid lock up. Drops closed, but if you do not release the button at the right moment, the blade bounces quite a bit. The button lock has been flawless through a couple hundred cycles.
Beautiful F&F. The handle is silky smooth, but the shape provides a secure and comfortable grip. There is a filler tab for the extra recess for the pocket clip.
My only serious complaint is that the pocket clip is too tight to go over the hems on my pockets.
From the Indiana Knives web site:
Blade Length: 2.95"
Overall Length Open: 7.6"
Handle Thickest Point: .49"
Handle Material: Titanium
Weight: 4.1 ounces
Pivot: Bearings
Locking Mechanism: Trek Lock Licensed By Vosteed
Reversible Clip: Titanium w/Ti filler tab (Clip/tab will be anodized to match handle)
Backspacer: Titanium
Hardware: Stainless w/T8 heads
OEM: Bestech
133 187 194 170 177
Blade Length: 2.95"
Weight: 4.1 ounces
Pivot: Bearings
OEM: Bestech
