- Jul 27, 2009
Hey guys, need some advice.
Backstory: I am hobbyist with a small basement shop. Obviously this is not an ideal place to make knives, but for the time being, it is all I have. I do not grind handle materials inside on my 2x72 (only with files, rasps, etc.. , I have a large HEPA air cleaner with furnace prefilter to clean air, and I clean up religiously (proper ppe gear always used) with HEPA Vac, water bucket under grinder..etc. Even with the HEPA cleaner, I have been worried about those super fine particles that even the HEPA doesn't collect and would never be collected or leave the shop (at least in the right way). I already had an extra 6 inch outlet that was originally an air intake for a wood burning fireplace and now no longer in use. I purchased a 12" dustproof 1500 CFM exhaust fan and I plan to use this as the solution in cleaning the air of the super fine airborne particles by venting outside from said outlet. The problem is the outlet itself is probably 15 ft. from my grinder.
Question: What would be more effective cleaning the air/be the best performing setup. Putting the fan close to the outlet itself, so it only had to push the air a few feet before it was through the wall? Even though this would be 15 ft. from the grinder? Or duct over 15ft to the grinder and put exhaust fan overhead of grinder itself? 1500 CFM is pretty strong, but I want to insure there is good air flow all the way to outlet and not leaving particles in ductwork. Shop room is approximately 8' x 18' or so. Can't move grinder closer to outlet.
Thanks for entertaining my strange question.
