Exo Flame Titanium Lighters
Feedback: +74 / =0 / -0
These are small titanium lighters machined out of a soild piece of titanium. You can carry these on your keys or tuck them away in a pocket or backpack. Their small design makes them very easy to carry and they take up very little space. When fitted with an o-ring, the fuel inside will not evaporate. This is a huge advantage over unsealed flint lighters, which loose their fuel to evaporation in a few days, even if unused. These are available with optional sandblasted finish, heat anodized finish, or both.Outside dimensions: 49.5 mm L x 15.5 mmInside dimensions: 38.4 mm L x 11 mm W
4 mm lanyard hole
Weight: approximately 1 oz with lighter fluid inside
Price is $100 each. I can add a glow dot on the cap for $10 and heat anodizing, sandblasting, for $10 more, or $15 if you want both. Kydex sheaths are available for these for $20.
How long cld one expect the fluid to last once filled?
Do the glow dots have to be "charged" by light?
What colors are available?
Are the lanyards with the rings available as well, and how much?
The fuel can remain inside the lighter for a long time due to the oring seal. How long it lasts depends on use bif you use it sparinly it will last a long time. The titanium rings are also available and so are the lanyards. The small rings are 15 and the larger ones are 30.
I was wondering all of the same things. What about the glow dots? Colors?
the fluid can be stored indefinately due to the oring which prevents it from evaporating. How long it will last depends on how often you use it.
The glow dots are charged by a light source and are $10 extra.
I have standard green glow and red, but green is the brightest color and lasts the longest
the lanyards with the rings are available. Lanyards are $5 and the ring prices depend ont he size. A small ring (about 1/4" wide is $10, a medium ring (about 1/2" wide) is $30. Larger rings which have a diameter large enough to wear ( I do make titanium jewelry type rings) start at $50 depending on the style. Hope this info helps.
