EXOTAC Life Cap
Mistwalker
Another piece of kit I've gotten lately is a Life Cap survival capsule from Exotac Inc., I'm really becoming a fan their products. It's made of carbon fiber and hard anodized tempered aluminum. The threads are squared blunt start threads for long term durability and cap seals with dual O-rings.
It's a cool capsule that can be tucked in a cargo pocket, worn on a belt, slung over the shoulder using some cord, or attached to packs in various ways using the multiple attachment points.
Part 1 of 2
I wrapped it with 15 feet of para cord, and then some McNett Self-Cling Protective Camouflage Wrap. Now I have multiple types of cordage on the outside which also helps with impact protection and sound discipline.
The cord shoulder strap also doubles as a lid lanyard to keep the parts from becoming separated at night and loosing the lid.
Stocking it is sort of a work in progress...
Right mow it has:
1 tube G.I. peanut butter (food or bait)
4 band aides
1 pack of steri strips
4 alcohol prep pads
2 packs of Emergen-C
5 REI storm proof matches and striker material
1 Exacto blade
1 bobbin of 8lb test line
2 fish hooks, (have to add more)
6 split shot weights of different sizes
1 sliding weight
1 5/32x2" ferro rod
1 5/32x4" Ceramic sgarpening rod
1 ESEE AH-1 arrowhead
1 signal mirror
1 TOPS folding survival saw
By utilizing some better organizing skills in putting the items back in there is more room, plenty to add some water purification tablets and I may take the peanut butter out and make more room...right now it's serving also as a space filler and packing material.
Now that it is at least partially stocked environmental testing will start this week.
This is pretty nice.
I have always said that I wish someone would make a waterproof capsule that could boil water. It would make worrying about water a none issue if they did. Put the O-ring in the cap, and make the tube 2''x7'' or so and you could boil 12oz. of water in it plus carry enough gear to get you through a few days if need be.
Have the attachment points like this one so you could attach it to a knife sheath so it's always there, and you can remove it and carry it anyway you want.
I never could understand why they keep making nylon pouches that do nothing but carry gear and they are not even waterproof, plus they carry little needed gear and can't be removed and carried in a pocket or any other way like this one can.
I look forward to your review.
Sweet review, I might have to find me one of those now.... my kit doesn't currently have much in the way of waterproofing, and this really fits the bill.
I don't think the carbon fiber is the ticket for boiling water, but can't say that I'm positive- anyone know for sure?
I was thinking the exact same thing, seems like a bad idea as it it bonded to the caps with an adhesive.... maybe not the best thing to heat? I could be wrong, but I share your skepticism.
No, I don't think you can't boil water in this one, but I could be wrong.
I was refering to someone making one that you could boil water in. I mean a nice aluminum tube that's threaded would be perfect. That's what I was talking about, but I do like this one. I would want something cheap and simple.
I'm not sure why they would wrap it in carbon fiber if it's an aluminum tube? Although CF does take a huge amount of heat without any problem at all. At least that's what I thought a friend of mine told me and he makes all kinds of crap out of it for everyone from private people to Hollywood. He did most of the figures in the movie Night At The Museum or whatever it's called. I'm not much into movies. So he knows about CF. I will have to ask him again to make sure.
I heard when they started using it for bike exhausts that there were instances of it delaminating if it got wet when it was hot- that may have just been an issue of the temp differential or something. But there's also the fact that at micarta and G10 (which I'm more familiar with) are not great heat conductors, so I assume (oh no, that word!) CF wouldn't be either.
I'm all for something like this but simple and cheap- did you see the price on this thing? I mean it is gorgeous, but I'll be getting mine right after I hit the lottery.
Thanks guys. No, I don't think this one could handle boiling water, and I wouldn't try it in the Ti version either because of the way they are put together. Personally I would love something like this in stainless with a one-piece vessel design and the attachment rings welded on for the same exact reason. I do love for every piece of my kit to fulfill multiple roles. However for the wet environment I spend a lot of time in I have been looking for such a capsule as this for a very long time. The carry options are limited only by the imagination, the size is adequate to get a good bit of necessary items in but not too large. I would really love it if it could also be capable of boiling water and hopefully someone will eventually make one, but for now I am just ecstatic to get this far. I carry a S.S. Nalgene guyot and it nests in a GSI cup so I have that issue covered for most cases.
As for the O rings I think putting them on the lid would be a real pain but they could always just be removed from the container prior to boiling water and then put back on.
The stainless Nalgene/Guyot bottle does this.
I have seen those, but I have never used one. Mainly because I'm looking for more of a last ditch kind of thing that will hold some last ditch gear and boil water. The bottle I have seen seems to be larger than I want with no way of attaching it to a kydex sheath.
I want to be able to have one nice neat little package that's a knife, and a small kit that can come off the knife and go on my belt, in my pocket, around my shoulder or where ever, but it's always together with my knife. I'm not a fan of pockets for gear, because that's all they are is a nylon pocket and do nothing else.
I don't want something that's to big either or needs another pouch to carry it. Something around the 2"x7" which will boil about 12oz. of water would be great. That would be something that would hold about the same amount as about four Altoids tins stacked on top of each other. Have four attaching points, two on the top and two on the bottom to tie off to a kydex sheath.
Then those four points could have 550 run through them to make a couple loops to wear it on your belt. The top loops would also be used to hold it over a fire for water.
For ME, that's about all the room I need for the things I want to carry, plus be able to boil enough water with a small fire to make it worth while. I can easily carry a space blanket, a BIC, a plastic bag for water, and have most of the tube left over for anything else I want.
Mistwalker, I have made a few tubes like this out of copper pipe, SS milk line pipe, and aluminum, so I have learned to pack these as well. When packing a tube, do not pack it in layers. You will run out of space fast. Think of packing it more like a box of drinking straws and have your items be able to go from the bottom to the top. Like a fire straw, don't make four of them 2" long, make one that's 8" long. Your packet of peanut butter, don't fold it, lay it flat along the side of the tube wall, then your emergency drink mix stacked on top of the PB. Have those small tubes, fishing and matches, stack on top of each other as well.
When packing a tube, a vacuum sealer works great. You can make sealed pouches any size you want. I make pouches for pills that I want to take. I lay the pills end to end in a sealed pouch. The pouch is skinny and long and goes from the top to the bottom.
Another thing I did was I packed a GOOD Sawzall blade like this one, that cuts in both directions. Grind the end if it's too long to fit in your tube. I pack a wood screw to attach the blade to a wooden handle I can make out in the bush. I don't make spoons, but I do make handles for things like this. I can't see wasting space for a plasic handle when I can make a wooden one out in the bush, and sawzall blades are better and cheaper than any hand saw I have ever used. If you put two layers of duct tape over the teeth of the blade, you will be fine, at least I have been fine. Just make sure you pack something to turn the screw. I pack a small swiss tech tool. They are pliers, and two screwdrivers in one.
http://www.amazon.com/Skil-94100-05-Pruning-Reciprocating-Blades/dp/B000BMBPGU
I think you get the idea here of what I'm trying to say. This way of packing also makes it very easy to find what you need and get it without unpacking layer after layer of gear.
i was totally interested in this until i saw the price.. gawd o mighty thats expensive.. nice write up though mist! as usual
Thanks man, this comment isn't directed at you or any particular person...I just find it funny how people will pick and choose where they spend their money. I know people who will spend over a thousand on a rifle, 6 or 7 hundred on a hand gun, anywhere from 2 hundred to 6 hundred on a knife, anoth couple hundred on a pack and then build their PSKs from Altoids tins and complain about the prices of other pieces of kit. I suppose it's all in wants and perspectives as always but like I said when someone mentioned the price of my hawk... my friggin t.v. that I seldom watch (and has little chance of ever saving my life) cost over $600.00...don't remember exactly...and I'll get a hell of a lot more use out of this capsule and any other piece of gear I own. I guess it all comes down to personal priorities and how much time one spends in the outdoors. Personally I don't want any of my gear "thrown together" or "second rate" if i can possibly help it. I have spent my time putting kit together on a budget and out of scrap materials when I had no other choices... but I make improvements as they can be made.
I bought a $5 stainless waterbottle at KMart to support my car's GHB. It has a 1 1/2 inch opening and if you roll/fold your soft pouches (4x4gauze,ClO2 tabs,betadine/alcohol wipes) to nest in an open top pill bottle with the child proof ratchet ground off it fits thru the opening. A piece of thin walled PVC would also work. It will handle most of the common PSK stuff excluding a signal mirror. You can section a piece of aluminum can to protect a HeatSheet or garbage bag taped or Ranger banded to the outside, also possible to wrap with 550 cord and attach with a light weight carabiner
i agree with this.. however, i am cheap lol. not really cheap cheap but you know what i mean. cant afford but so much. :grumpy: i do like this piece of equipment and it seems it will serve you very well.. in your case the price is justified bc you will use the snot out of it. for me, no. i still enjoy reading your write ups though. you know what works and what doesnt.
I know man and thanks. As I said that wasn't directed at you. Mainly it put me in mind of some friends I used to hang out with a lot. They'd spend hundreds building custom rifles and then run only the cheapest ammo they could find through them...no matter where it came from. They spend $200.00 on a pack and then load it with cheap Coleman gear (Coleman aint what it used to be). $30,000.00 on a truck and then use only the cheapest gas and oil...and a lot of other similar things...and not because they didn't have the money because they sure didn't mind paying my $50.00 p.h. fee for my work and four hour minimum to fix some of the simplest things
Once someone questioned my Sebenza's worth to me, after asking what it cost. I then asked them where their $500 golf driver would be when I was passing my Seb down the line to a relative.
I have an company Iphone, but what about folks who pay for their own? When that $600 Iphone is obsolete in a year or two, my Sebenza will just be getting warmed up.
Different strokes, and nuances within. I don't think anyone's really right or wrong. I love me some nice, durable gear!
Professor.
I understand exactly what you mean. The maker/manufacturer may determine the prices but in the end it is the end users who determine the worth.
Good review. Cost is relative. A friend of mine was shocked at what I spent on an RMJ hawk, but had just shelled out 2k to change some windows in their living room.
Yeah, cost is completely relative, and I have some similar friends. One spent nearly four grand on a home theatre system, and then went bug-eyed and slack-jawed when I answered his question as to how much a hawk like my Shrike goes for. He's a member of the 169th Artillery...
