- Apr 20, 2001
I have actually taken apart my CQD MK II (shhh! don't tell MOD) because when I first got it it was overloaded with grease of some sort - it was so bad it made a squishing noise every time I closed it. Can't have that!!
It's a fairly simple design, but it might be hard to explain without visual aid. That said, here goes:
The button is attached to a "pin" or plunger that has two diameters. It's very narrow in the middle, then it flares out on the other side. So you have button-narrow-wide. The blade tang, under all but the completely open position, extends out far enough that it can only be matched up with the narrow section. When it reaches the fully open position, a spring pushed the plunger up so that the wide section engages a notch in the blade tang. Thus you have to push the button back down, thereby making the narrow section line up with the blade tang, in order to close it.
The secondary slide lock simply sticks a barrier under the plunger so that it cannot be pushed down.
I hope that was readable, and somewhat clear. It's hard to really figure it out without taking the bits apart.
