Extrema Ratio TFVDL titanium handle
Like new, never used
$300 shipped, Paypal, no trades
BLADE LENGTH: mm 97
TOTAL LENGTH: mm 287
BLADE THICKNESS (MAIN BLADE): mm 2,5
BLADE STEEL: N690 (58HRC)
WEIGHT: g 280
Developed as an instrument for jump masters, to cut through the static line in case of entanglement, it has revealed itself as an innovative and versatile emergency tool for accident scenes in both the military and civilian environments.
The tool is made of a central piece which works both as a handle and as the receptacle for two folding blades which are hinged on its end.
The principal blade is beak shaped, with a scissor opening to 55 degrees revealing a third blade fixed to the central piece and with which it forms an upside down V. The automatic opening is activated by a button found on one side of the central piece. It is used to select and cut through static lines, ropes and belts under tension even when close to the body.
The secondary blade, less specialized, transforms the tool into a folding knife for general use.
BLADE LENGTH: mm 97
WEIGHT: g 280
