Thread has been moved to:
http://www.bladeforums.com/forums/showthread.php/863489
ESEE-RC-4 Black Plain Edge Blade, Black Canvas w/Green Liners
ESEE-6-6P-B Black Plain Edge Blade, Black Canvas w/Green Liners
Extrema Ratio Ultramarine Knife
Total length: mm 298 (11.73 inches)
Blade length: mm 150 (5.91 inches)
Overall Length Including Sheath: mm 320 (12.60 inches)
Overall Thickness Including Sheath: mm 55 (2.17 inches)
Weight: g 375 (13.28 ounces)
Blade Thickness: mm 6.3 (0.25)
Blade Steel: Bohler N690 stainless steel, X105CrCoMo182
Serrations: Partially serrated blade
Handle: Polyamide (Nylon)
Sheath: Double sheath
Diamond Sharpener: Yes
ADDITIONAL INFORMATION:
Comes with two diamond sharpeners: one is for the blade and the other is for the net cutter.
To protect the Ultramarine from damage when not in use, a flap is incorporated to cover both the sheath and the knife.
A strong pull will allow you to disable the O-ring and the retention system.
For entanglement emergencies, the Ultramarine incorporates a specialized net and line cutting system.
New with case,
New with case,
