knifetester said:
I think the distinction is logical as well. If you want to hold a maker liable in warranty for all statements made, this will result in no makers sharing knowledge or their testing process.
Most makers are well aware that I use knives heavily and will actively check performance claims. This doesn't stop a lot of them from talking to me about the performance. Many get really specific in emails so I can actually try to repeat what they are doing as they want me to do the work as they are interested in the confirmation or refutation. My point of view is quite simple, your knives should be able to perform as you describe them performing. That is all.
He has also stated that is not the intended use of his knives. Therefore, it is not logical to hold him to strict liability for those statements.
Consider the statements :
"I only did this to prove to myself that my D2 knives with my heat treat are up to hard use in the field."
Now isn't this a statement of performance to the consumer, clarifed in :
"I was merely employing some extreme conditions that may be encountered in the wilderness. The possibility of hitting rock and metal in the wild is very real."
However, lets say he never said any of that, and just assume you did it out of curiously and the blade performed massively different, isn't it still evidence it is obviously defective and should be replaced?
Here is a similar question, let's assume that Razorback got a new batch of steel from a different manufacturer and repeated the tests, and the knife performed radically worse. How would he (or you) react?
How would you feel if you contacted the steel manufacturer and they said "What are you getting on about, that isn't the expected use of your knife is it?"
IT is not logical to extend warranty liability for "bulldozer run over failures" to him based on his comment.
Depends on how it is presented, if someone says, how durable are your sheaths and that is the answer it certainly is a promotional claim. You can easily word it otherwise though :
"Yeah it got ran over, it survived ok, but I think I got lucky there."
It is clear this isn't a promotion of performance.
I think a more suitable comparison is a measurement at 1/16" back, where Scott's knife is .075"
Ang Khola : 0.037"
K2 : 0.015"
Safari Skinner : 0.024"
Temperance : 0.020"
Don't have the U2, but it is close to flat there, so half the 1/8" thickness.
[vs 100]
sak_collector said:
...they test it and can only cut 90 pieces, then would I be subject to claiming my knife is all hype?
You would have to argue the difference is significant and it would be hard to do so given difference in cardboard, user cut speed, and a reasonable variance from knife to knife.
I try to be fairly controlled cutting cardboard and the results are never exact from one run to the next, even averaging 3-4 runs the precision is rarely below 10%. One shot comparisons would be expected to be significantly more divergent.
In the above case the user and maker would discuss exactly how they did the cutting and the maker would have to decide if the difference either indicated a defective blades or was simply due to differences between him and the user.
If I was the maker the first thing I would do is just ask them to repeat it a few times to check the consistency, and knowing how it was when I did it would be in a position to make a decent evaluation.
This actually came up on the Busse forum. Someone took a BM and attempted the cutting Busse has done in the past and got different results. They just discussed the method and worked out why the results were different.
I don't get the same results Wilson does when he does rope cutting for example because I use a different finish and cut in a slightly different manner and use a different method to judge the stopping point.
-Cliff
