If the shoulder fills out the bottom of the eye, then I don't see an issue. That looks similar (from the top view) to many of the axes I hang. The stock wedge may be inadequate, but I don't usually use them anyway.
What's the deal here I thought there were only 2 common eye sizes, cruiser size on 26-28" handles and regular size on 32-36" handles.
Gee, you're gonna need one heck'uva wedge.
The part that concerns me is not the thickness of the eye, but the length of it. A wedge could fill up the narrow dimension, but the tongue of that handle isn't wide enough to reach the front and back of the axe eye. That is what would stop me.
John
The important things is keeping it from splitting when you drive a serious wedge it-- that means sawing the wedge kerf about 7/8ths of the depth.
But do you think the tongue of the handle would angle that much in? If I was going to go ahead with it, I would add extra pieces of wedge to fill up the front and back gaps. If it's just empty space, the handle might lever out one day.
The thing is, you might not be able to find a handle with a big enough tongue. So either you make your own from scratch or you work with what you got and hope for the best.
Have you ever tried re-cutting the kerf? That is, make your first cut as normal, than clamp the wood together in a vise and re-cut that same kerf to two thirds of the depth of the first cut. Then clamp again, and cut again, this time one third of the depth. What do you think of the idea?
