for sale great condition, I fear using LNIB but it has never been carried or have any scratches on it.
OLight warrior X flashlight.
2000 lumens Rechargeable flashlight. batteries included
everything included, usb/wall charging cable, nylon carrying pouch, clip, etc.
(no Box)
$sold shipped CONUS *** pending sale to trukreltrog
Paypal , will ship and provide tracking next business day.
This thing is awesome but I bought it intending to use it for camping or clearing the house for bumps in the night but I have never used it, it just sits there on my nightstand. I have a baby coming now and just need the cash more than a flashlight that I never use. I have never carried it, taken it anywhere, it has only sat on my nightstand. it is just as the day I purchased it. it can have a pressure switch and mount if you want to mount it on a cqb gun.
factory info:
"The Warrior X represents 10-years of producing the Warrior series tactical flashlights. It features a massive 2,000 lumen max output, 560-meter beam distance, and can endure harsh 2-meter drops without even a cracked lens. The Warrior X also integrates our magnetic metal tail switch with built in charging, and a never before seen vibration battery indicator. The Warrior X is here to meet the needs of any hardcore lifestyle.
Have you ever experienced trying to find a spare battery because you ran out of power? How about the low power indicator suddenly turning on when you want to be discreet?
The Warrior X takes care of these issues. We have equipped an internal motor which vibrates to remind you when the power is low. The almost silent vibration will let you know your power left even in darkness to help you prepare beforehand."
Beam Distance (ft) 1837
Beam Distance (m) 560
Max. Performance (lumens) 2000
Charge type Magnetic USB charge base
Compatible Batteries 1 x Customized 18650 3000mAh Battery
Light Intensity (candela) 78400
Light Form Compact/tight focused hotspot. Ultimate beam distance.
Lens / Reflector Type Smooth reflector (central area and flood area)
Mode Operation Tail Switch
Form/Size Factor Medium size (Permanent Marker)
Series Series M (Tactical, Military)
Unique Characteristics
(no Box)
factory info:
- Using a 15A high-discharging 3000mAh 18650 lithium battery, the Warrior X produces a 2,000-lumen output and 560-meter throw.
- Thick aluminum alloy body and a 3mm tempered glass lens allows the Warrior X to endure harsh 2-meter drop test.
- Quiet to conceal & easy operation: Wear-resistant metal tail switch built for environments where stealth is key.
- Green & rechargeable: Charge directly from the tailcap via the Olight MCC USB charging cable and avoid frequent battery change.
- The world’s first vibrating power indicator.
- The world’s first magnetic remote pressure switch.
