Fall Beckerhead Rendezvous on the Nez Perce...September 21, 22, 23.
heard from Steve Johnson - he has jury duty that week, so can't go.
I'm not likely to make it due to truck woes -- I may be spending that week rebuilding a bathroom to help raise funds for a down payment.
my sentiments exactly -- if I can find an extra $15k between now and then, I'll let you know.
Damn, you folks picked a knice place to get together. Have fun, stay safe and take lots of pics, play with lots of knives, chop lots of stuff and cook lots of bacon. Dirty bread is a great campfire snack. Goes great with beer too.
Here’s a quick recipe with instructions.
Szalonna (pronounced sulena) is the Hungarian word for bacon. This particular recipe calls for a smoked szalonna. Essentially it is a very thick layer of pork fat with the rind. see the attached image
Ingredients:
1 Large piece of szalonna (as thick a piece as possible - usually available in a good Hungarian or Polish deli or provisioner)
2 Loaves of sliced, fresh, baked bread of your choice
4 Cucumbers - peeled and sliced (English or Hot House cucumbers don't need to be peeled)
3 Red or green peppers - seeded and sliced into rings
2 pints of grape or cherry tomatoes - sliced in half
2 Large onions of choice - sliced thin
Salt, Pepper, Hot and sweet paprika for seasoning
Preparation:
In a safe location, build an open wood fire. Adding chunks of hickory wood to the fire will enhance the flavor.
Take a knife and carefully slice the szalonna into pieces about 4 x 6 inches. Now take one of the pieces and again with the knife, cut two small slits in the rind. One slit should be close to one end and the other should be close to the other end.
Now take a wooden dowel about 3/8 of an inch in diameter and sharpen one end. Insert the sharpened end of the dowel into one slit in the rind. Tunnel underneath the rind and bring the end of the dowel out of the other slit.
Now take your knife and cut a criss cross pattern into the fat side of the szalonna. Don't cut all the way to the rind. Make your cuts only about a 1/4 inch deep.
Layer slices of bread onto an aluminum foil lined tray and place on a table near the fire.
Put all your fresh sliced vegetables on a seperate tray.
Take your skewered szalonna and hold it over the fire while slowly turning it. Soon the fat will begin to run. Now drip the fat onto the bread. You will probably be able to thoroughly cover only a slice or two with drippings. Return the szalonna to the fire and repeat the process until all the pieces of bread on the tray are sufficiently covered with drippings.
Now begin layering your fresh vegetables onto each slice. Begin with cucumbers, then peppers, tomatoes and onions.
Drip more szalonna over the vegetables. At some point, the outside of the szalonna will become crisp. Slice the crisp pieces off and add them on top of the vegetables. Now season with a bit of salt, pepper, and paprika. You can even add some crumbled feta cheese too.
Enjoy!
i hate i can't make this one, but also, it's a little too roughing it for me at this particular juncture - hope to remedy that. i'm about slowcation, not fastcation...
that said, i hope to swing out that way for a mosey in a more relaxed fashion. i'm travel challenged this time of year. there's 100 things i wish i could be doing, but property ownership and other woes.
Hey Tom.... No banjos but, the sound of Elk bugling Will definitely keep the nervous awake....Am I gonna see you at BladeWest???? E
