- Feb 13, 2018
Nice!!My CKF MILK:
Nice!!My CKF MILK:
Little tough to see in the video, but I was holding the MILK at a angle (side to side, as in laying towards the lock side) and slowly raising it towards straight. Held straight vertical, if immediately falls.Nice!!
Yep. Its awesome! Ffffffff why do all ckf knives have to be so gd big...Little tough to see in the video, but I was holding the MILK at a angle (side to side, as in laying towards the lock side) and slowly raising it towards straight. Held straight vertical, if immediately falls.
True, the Marksman is very bouncy but it is also totally safe to operate. Your fingers are never in the blade path.The Buck Marksman is the worst--it feels completely friction-less, but if it doesn't deploy all the way it ricochets back at nearly the same speed it departed with.
Yup.G&G Hawk TAD Dauntless
It's bigger than you want, but the Buck Marksman does this. It's not because the blade is heavy, it's because once unlocked the lock doesn't make any contact with the blade and it is on bearings.I mean none of these are still really free fall gravity only shut you know.
Does that really count? It won't fall shut with your finger there...unless it's wickedly sharp.Agree with above. Most ball bearing framelocks will fall shut as long as you hold the lockbar (and thus the detent ball) off the blade.
Does that really count? It won't fall shut with your finger there...unless it's wickedly sharp.![]()
Only my Shiro 95T and my North Arm Skaha truly fall shut with the lockbar against the blade tang. My NeOn Ultra-Lite falls almost to the detent ball and just stops short and I've got a couple others that are close. I often put a little blob of FinishLine on the detent ball to grease the skid, so to speak.I think though for liner and frame locks true fall shut where you don’t give the knife a little shake is less common to see. Especially on knives with smaller lighter blades. The detent pushing against the side of the tang will provide enough friction to prevent a true fall shut.
Though I run my bearings knives dry. Maybe a little lube on the knife and detent ball will promote better fall shut action on liner/framelock knives.
On frame- and liner-locks I consider it dangerous.Drop-shuttiness is kinda cool, but hardly a necessary or useful feature in a frame- or liner-lock knife. I just want 'em free enough so I can forefinger-flick 'em closed.![]()
Certainly can be, as my right thumb knuckle will attest.On frame- and liner-locks I consider it dangerous.
