How did you have that corrected? Send it back to the factory? I'm glad you like the final result!I know I mentioned this somewhere before but -- The TK-1 I got was poorly balanced as the full length, width ,thickness tang put the balance point too far back -butt heavy. About my first use , on a deer ! Had that corrected so I then I could test the steel ! Now my favorite hunting knife. 3G ? Excellent steel !!
That's the first ive heard of a bad heat treat from Fallkniven. That sucks that you were lucky enough to get a bad one.I have two knives in 3G, the Fallkniven TK4 and U2. They seem like very different steels. The blade on the TK4 holds an edge very well, but the U2 was not in the same league. I suspect that hardening and tempering wasn’t quite right in the smaller, U2. I have seen the same thing in VG10 blades. It is usually a good steel, but I have one knife in VG10 (not Fallkniven) that seems to have much softer steel. I think that the problem overall is that manufacturers heat treat the blades in large batches, and some blades come out better than others.
