I don't understand the philosophy of convex blade on a small fixed blade knife. Now, a convexed edge, absolutely. Is it all about batoning? If so, then I guess I don't understand the philosophy behind batoning. I know it is a survival technique but I personally have never needed to waste the energy that batoning requires in my backcountry outings. I guess I wish they made an F1 with a full flat grind. I'll never need one even if they did make one because I'm very happy with my Linder SuperEdge I which is FFG.
I totally agree about the obsurdity of batoning. It makes no sense when you can find smaller sticks. Plus I've never heard how you're supposed to break the logs into manageable (16") pieces before batoning. If you have an axe/hatchet, that would be a much better tool to split with. Most of the pics of people batoning include chain saw cut logs...
On the other point you made: If you are concerned about the very small differences between full convex and full flat ground, then you are being way to picky on how your knives perform. We're talking about very minute differences in where the steel is located and seconds of angle of bevel change... If you haven't handled a Fallkniven, then that would make sense, if you have then I don't really understand what the problem with either full convex or FFG would be...
To the OP: I own the BM Rant and the Fallkniven F1. I choose the F1 over the Rant everytime I go out for two reasons: The F1 is the perfect size blade, I like them a bit smaller. The F1 comes with the PERFECT Zytel sheath. Like a Mora sheath done right. It's compact, super protective, and positively holds the blade.
Another recommendation for the Fallkniven F1. Thats only because i have no experience with the Rant and Master Hunter.
Just some bonus info...The founder of Fallkniven used to be a Cold Steel distributor for Europe. He then parts ways with Cold Steel, and the rest is history. No wonder the 2 knives look so alike.
By the way, i think the new Rants are made with 440C steel. BM has also launched a few extra blade shapes and replaced the old sheath with a nylon one.
Heres a comparison of the Rant with the F1. As you cans ee its much bigger than the F1. ts closer in size to the Master Hunter. The pic i borrowed from: http://www.knives.lt/sites/default/files/images/F1-vs-BM%20Rant.jpg
It seems most everyone is putting out their copy of the Fallkniven F1 knife pattern intended for survival/hunting/camping:
- fixed blade
- black textured composite handle with finger guard an lanyard hole
- 4-5mm hollow-ground stainless blade, about 4 inch long.
...On the other point you made: If you are concerned about the very small differences between full convex and full flat ground, then you are being way to picky on how your knives perform. We're talking about very minute differences in where the steel is located and seconds of angle of bevel change... If you haven't handled a Fallkniven, then that would make sense, if you have then I don't really understand what the problem with either full convex or FFG would be...
^ your correct- the tang is larger (wider) on the diy version, so in addition to whatever scales you choose- you're adding even more weight
you do however get the exact scale material and size/shape of your choice![]()
Well that's kind of why I started this thread. The F1 has achieved cult status since its introduction in '95 and has been copied by some reputable manufacturers, some of which are listed up top. Said manufacturers have had time to come up with something good (it's been 16 years after all). So does any of the competing product give the F1 a run for its money (or half of it)?I have the F-1 and one of the older Rant bowies with metal guard.
no comparison between the two knives.
size feel blade shape ... everything is different aside of the rubber type grips.
I would TREAT the F-1 alot harsher than the RANT bowie ... just by the FEEL of the knives.
*F-1 is now a proven design and as far as I am concerned it is a BENCH STONE OF A KNIFE ... others should be judged by.
Price is right on them and 1000's of owners cannot be wrong.
