False grinds and top clips I grind first and take them up to a fairly high grit before switching to primary bevel. This is how I was taught to do it, it's easier to match at the tip. Swedges I do last.
I grind a blade in layers of finish.
The ricasso is first to be finished. Layer One!
The tang ground to fit the ricasso. Layer two !
The distal taper ground to the ricasso. Layer Three
If you grind a blade in layers of finish; the false edge is ground before the bevels. Layer Four
The bevels go over the swedge; if you finish a blade by layers. Layer Five
The finished sharpened cutting edge is the last layer of finish. Layer Six
I used to work in a bakery, is, no doubt, the reason I do it this way.
Cake decorator.
Fred
