False Edge - What is it?
fitzo said:
You'll find that there is no chortling at first knives and naught but encouragement. :) Though there is the occasional surprise at a wonderful "first knife", most of us had much humbler beginnings.............
And you're quite right, there are many knowledgable, helpful people on this forum. I have learned a great deal here.
I don't even think my fist knife could be classified as a "knife" :D More like a primitive chopping device from the 13th century....
And I would also like to thank all the people who talk on these forms. You’re all very helpful, especially to Noobs like myself. (almost more than you relize)
Sir, The Clip or swedged spine, ie: as in a Bowie, is called a false edge. It has nothing to do with sharpned or unsharpned. Sharpned, it is refered to as a sharpned false edge. False means not running the full length of the blade, as on a dagger, which has two full edges. Thanks Mike Lovett http://home.earthlink.net/~michaellovett/
Hi Bruce,
Welcome to this wealth of knowledge and nice guys called BF.
ps. I made one of those "oxymoron" " false edges that cut" on a knife for a guy.:D
Well, what can I say, the man wanted a false edge that cuts and we did not know what else to call it 'cause it looks just like a false edge, but it cuts! What would you have done?:eek:
I posted a pic.
Mike
http://usera.imagecave.com/miden/knife-1.jpg
hehehehe
It's one of those terms that have differing meanings to different people. I found another link that said it HAD to be sharpened to be a false edge. :eek:
The main thing is I think we can agree it's a beveled area other than the main edge.
That' a very nice knife, Mike.
PS. I still think it sounds like an oxymoron, sorta like "icy hot". :D
Hey Fitzo, thanks for the kudos re my knife.
Yes, got to agree about the oxymoron thing, it is like an "honest politician":D
"It's one of those terms that have differing meanings to different people. I found another link that said it HAD to be sharpened to be a false edge."
Now there is an oxymoron within an enigma! hoho
Mike
miden said:
Hi Bruce,
I posted a pic.
Mike
Very nice job sir!!! Looking Good!!! :thumbup: http://home.earthlink.net/~michaellovett/
Wow, coming from a man of your stature that is a very big compliment Mike Lovett, thank you sir!:D:D
I called this a double edge and it is sharp, but I may have named it wrong:(
this one didn't run back so far
Oh well:)
No comment!!!!:D ;)
Well, other than to say I like the knives, that is! :)
Oh well:)
Dan, all I can say is Your right. That knife is "Sharp" in more ways than one! Looks like one sweet dive knife!.
This knife I did actually has three different bevels,not the best picture but you might be able to see what I am talking about..The main cutting edge then a full back edge that is not sharpened so it could be called a false wedge,then the clip is also a different bevel that is sharpened but is also called a sharpened false edge (not the main cutting edge)
Now this one has a back edge that is a narrow grind but sharpened all the way,called a false edge or sharpened false edge...
This one has a full length false edge that is not sharpened thus a false edge
you can see others here or around my site.
http://www.beknivessite2.homestead.com/album7.html
The reason I have posted this is I get around the False edge statement or sharpened false edge statement by calling them a "Back edge" the only time I call them a false edge is when it is a bevel cut into a clip that is in no way sharpenable,these are put on the clip to reduce the metal on the back edge of the clip from grinding in the main bevel so the knife has a thinner point section thus cuts and penetrates better.so in my opinion if it is sharp or close to sharp it is a sharpened back edge or just a back edge-and if it is a stock reducing bevel it is a false edge...not sure if my thinking is correct but it tells what I have put on a knife better in my opinion..not that that is worth that much.
now to your quenching problem,you have a little longer window with 5160 to quench than you do with some of the other carbon steels,you figured out the fact that you cant quench in a thin layer of oil.Make your self a quench tank that gives at least three inches of oil deep then put a block of aluminum in the tank that will let you set the edge of the blade at the depth you want your edge quench to be at,heat the oil,now when you set the blade in go tip first then rock it down to the point you want the edge to stop at,now dont rock again untill all the color is out of the back edge (black) now you can rock it if you want or stick the whole blade down in the oil tank untill cool,then go temper it in the oven.If you are grinding the bevels in the blade before you quench dont make the edge to thin,as you will burn some carbon out of the edge when you heat to quenching temp.thus a little bite of the file will occur.The old saying that a good handmade knife will not reach it's full cutting potential untill after at least 4 sharpenings is due to this,so if you leave your edge a little thicker then quench and finish grind you will grind off this slightly carbonless part of the edge and thus your knife will be at full cutting potential when you test it the first time.Dont use the brass rod test untill after you do the finish grind on your edge either or you will get a false reading..Hope I have made sense here.
remeber this is all just my 2 cents worth and you can take it for what it is my opinion.
and welcome to the forums..
Mike and Dan,Awesome knives from both of you..
Bruce
bad pictures though,, those were customer designs but did turn out nice for dive knives..
Bruce nice Bowies as usual,, but that middle one is bent some:( :D just kidding nice work..
Very Sweet knives Dan and Bruce.:D
Dan, very work-like looking.
Bruce, those designs are pretty unique. I particularly like the third one.
Mike
Bruce, welcome! You will find that the wonderful people in this forum will laugh with you but never at you! ---Sandy---
