I like a curved handle when primarily using the bit, but I do not prefer using a curved handle in reverse geometry extensively, as it is accentuating the opposite geometry that was intended and works against you. It is sorta like having a curved double bit ax handle.
After reading this thread I'm thinking my 4# miner's axe with a straight 20" handle may be preferable for carrying. The miner's ax can be carried on my tool belt in an altered leather hammer holding loop.
Questions for you guys using a 28" haft:
1. Do you ever carry a 28" ax on your belt?
2. Do you use the same ax for limbing then?
3. Do you use thin flat cheeks instead of the high center cheeks?
I don't carry in my belt. How depends on what I'm doing, how far and how much fuel I need.
I've got a pack set up for just this, that I'll put it in sometimes. Usually the long range method I use. All my saw gear goes in it, saw on the pad over my shoulder.
I have a saw scabbard that carries an axe perfectly. Theres a little place for file, bar tool and a wedge. If I'm just cutting one or two down not too far in, I'll wear the chaps and my wedge pouch, and throw the rest over my shoulder.
Others, like falling on a fire line where I need a lot of fuel, I poke the handle through the dolmar handle, and carry that over a shoulder, or if I have a swamper he does.
Or if I'm just cutting a roadside I carry my axe along in the other hand and keep most of my stuff at the truck.
Just a few ways I've come to prefer.
I don't use a falling axe with a thin bit. Some are flat, some high center but in reality they're all similar thickness. This is not a job for thin light tools in my case. Either way you can get a toe or heel in a kerf far enough to know what you need to know.
In use I'd have an axe sheath on all these.
