Feather Pattern Revisited
Ok, so I know how to make the feather pattern, and understand all the techniques involved, except for maybe one. Drawing the blunt edged knife-like object down through the billet in order to get the Feather effect. I've seen how a couple of you do it, which is sort of a handheld object, but this seems inefficient. I'd love to see various ways to accomplish this trick. To me, a stationary blade would seemingly be the best, but the problem of room comes into play if using a press.
So, how do you guys cut through the billet to form the feather pattern?
Pictures welcome!!!
Thanks,
Robert
Robert, its a case of using what will do the job, or equipment you have. We used a blunt hot cut under a press and when it started to go off to one side, we used a 14lb sledge hammer for fine tuning.
Mick.
I am interested in this also.
If too sharp a cutter were used, the stack would be sheared and I don,t think that is what is needed.
If anyone can post a photo of a good cutter profile it would be really useful.
Fred
The blunt hot cut we used was about 1/4 to 5/16 wide at the "nose" and ground to be the same profile as a similar sized piece of round stock.
The thing to do is try the blunt cutter on a piece of mild steel first and see how it works, if it starts to cut, then blunt it some more.
Mick.
Mick.
Thanks Mick! Thats about the size of the cutter I have. This cutter is 3 inches across the face. I'm going to jig it up, in the press and save my arm.
Fred
Fred, one thing I would suggest is having the block sitting perfectly upright, grind the top and bottom faces if need be. Also put a grind line across the top so in the "heat of the moment" you have a datum mark to line up the blunt cutter.
Mick.
