Less AO knives, and more frame locks, especially with a 3" blade length, for us who live in areas with stricter knife laws. I'd also like to see a Mini Cyclone with a Damascus blade and a satin finished or stone finished S30V blade.
Dave
"CRU-WEAR is an air-hardening tool steel, heat treatable
to HRC 60-65. Designed as an upgrade to D2, it offers
better wear resistance, greater toughness and higher
attainable hardness. Compared to the chemistry of D2,
(D2 = 1.55% carbon, 11.5% chromium, 0.8% vanadium,
and 0.9% molybdenum), CRU-WEAR has less carbon
and less chromium, but more vanadium and tungsten.
Both D2 and CRU-WEAR contain carbides for wear
resistance, but CRU-WEAR has more vanadium carbides
than D2. Vanadium carbides are harder than chromium
carbides and are much more effective in providing wear
resistance. Because CRU-WEAR contains less carbon
than D2, its overall carbide volume is lower, making it
tougher than D2. (Note: Although CRU-WEAR contains
fewer total carbides, it has more of the type of carbides
that are most effective for wear resistance.) CRU-WEAR’s
higher attainable hardness results from the fact that it
contains sufficient tungsten and molybdenum to cause a
secondary hardening response, (up to HRC 65), which
does not occur in D2. Finally, CRU-WEAR tempers at a
higher range (900-1050°F) than D2 (400-600°F), so it is
more compatible with a wide variety of surface treatments."
