- May 3, 2006
Hi Barny,
Wow! That was good luck that you had rain right after you built your shelter, so you could see how it held up.
A couple of things that will help:
-- FLIX
- First, the tarp must be pulled tight so that it doesn't sag and allow rain to collect. Use cordage and pull the tarp tight from the sides and peg it at the back. This will also add to the stability of the shelter. You don't want to rely on the skeleton alone, especially when you are using relatively small sticks.
- I noticed that you had some extra tarp hanging off the front of the shelter. This can be pulled tight either extended outward from the peak or straight down, but shouldn't be left loose.
- The "floor" section of your shelter should have a smaller footprint than the roof, to reduce the rain collection.
- In a survival situation, you will want to select your shelter site with an eye to drainage.
-- FLIX
