- Apr 4, 2007
Re: expectations... been there, done that. The first unit (of whatever) is close, and the second is farther off the mark. Or the first time, the mechanic forgets to tighten a bolt, and the second time he forgets the oil plug
Re: re-centering it. I'm not going to argue the philosophical on this one, since I've fixed plenty of new stuff before. Pragmatically speaking, though, if I try and don't succeed - or worse yet - mark a fastener head, it's mine... not centered, and now damaged.
Finally, as I said up top, the blade spine is parallel to the scales - all the way until the last inch where the sides are ground down to the point. So either the grinds are asymmetrical, or there's some minor warp or bend in the last 3/4". So adjusting it so the tip is centered will mean the middle of the blade will not be.
Thanks for all the inputs, and I'm glad I'm not the only crazy one here.
Ok sorry for my last post I should have checked for a follow up. Yeah from what you are describing it sounds like a wonky grind or a warped blade possibly from heat treat. There are way to try and straighten it but its far from an optimal solution and I wouldnt recommend it. My suggestion is to return it. I have OCD (diagnosed but in control) and it sucks especially when it has an effect on hobbies. And as someone who knows exactly what you are going through I can say it will most likely bug you. I wish I could tell you what I did to lower my expectations. It wasnt one single thing. but I used to let hairline scratches drive me mad even if they could only be seen with a jewelers loupe in direct sunlight at unique angles. Things dont bother me like that anymore. Only if there is a true serious defect. And yeah I consider off center blades defective if they cant be corrected.
