- Aug 6, 2007
Got the grill tank filled Friday, figured I'd take the weekend to put the new forge through her paces. Took a few minutes to get used to what heats up and where on the bar, and where the sweet spot in the forge is, but other than that it is very good to work with. The only thing I have a peeve with (and BARELY a peeve even) is the long heats, but other than that no problems whatsoever. The forge get's right up to temperature, and I found I was forging at 2 or 3 PSI comfortably and relatively quick. I worked some heavy stock (3/8ths thick 2 inch wide 1095 from Aldo) and some light stock (1/4 thick by 1 inch wide 1084 also from Aldo), the 1084 was in and out pretty quickly, had to bump it up to 4-5 PSI for the thick stuff. The only design change I would make to the forge would be to have a small port on both end doors instead of just the front, because to work long stuff you have to open the whole big back door which vents out alot of the heat, but I will call NC and see if I can get them to send me another door with a port in it and I will change it out.
Felt really good to get back to the hot steel and hammer and anvil, forged out a sword from the 1084, and started on the long blade of a daisho set (katana and wakizashi) from the 1095. Got blisters all over both hands, been out of the forge TOO LONG!!!! Got one on the side of my index finger on my hammer hand that looks like a cherry tomato :barf: . Also, a gas forge needs to be set at a higher height than a coal forge, gotta build a new table for it.
