I'm getting quoted, and some might be just a little off the mark or need clarification.
The problem with corrosion of 3V is in fact oxide contamination in the base powders from which the steel is formed. This may be as small as parts per million, maybe even less of the 3V steel particles that are hipped to form the final steel. Yes, that oxide is rust, but the problem is not rust in the conventional sense, but those tiny rust spots are a nucleus for attracting/trapping additional oxygen which promotes further rust in the same area. Absent these nuclei, 3V is very corrosion resistant. I etch my 3V blades after they are done to a high quality brushed finish, then lightly rebrush them after etching. I THINK this removes those surface oxide nuclei, but in any case it seems to prevent the rust spots that might otherwise form.
All that said, if you put a light coating of a teflon containing synthetic gun oil (I use Birchwood Casey's), it seems to protect the steel forever. I've never had a problem after a single light coat of such oil, even a couple years later. I think this is because any initial (microscopic) spots attract the oil by capillarity and prevent further oxidation in the area where it might have formed a visible spot.
To put this in perspective, however, on an unprotected 3V blade having an area of maybe 1-1/4" x 6", you might see 6-8 spots when the problem arises. As has been said though, those spots sit atop a pit which can be fairly deep and not easily removed.
If anyone here thinks tool steels are meaningfully protected by a patina, you'll find 3V will corrode a whole lot less than your tool steel, patina or no.
Actually, this whole subject pisses me off because S30V was SUPPOSED to have been a tweaked CPM-3V, since all 3V needed to be corrosion resistant was a little help, NOT a MAJOR overhaul. They either had to remove or neutralize the tiny amount of oxide contamination or add just a little more free Chromium to surround it. By doing so they would have retained most if not all of the toughness of 3V even at the expense of a little hardness. INSTEAD, they added a whole bunch more Chromium (14% instead of 7.5% as in 3V), then added a ton more Carbon (1.45% compared with 3V's 0.8%) to make it hard again, which made the steel completely unlike 3V in every respect. THEN they added another point of Vanadium which took it to 4% and still called it S30V instead of S40V which it is. I can get very emotional on this subject...
