When doing a logo, or customer intials,I clean the blade with acetone, MEK, or even ammonia. The etching surface must be free of oils including from your hands.I then apply the reist, for intials I use vinyl letters from an office supply store. I cut out a pattern from the vinyl laminating sheets to enclose or circle the intials, I cut out arrowheads, leafs, whatever then surround the logo with modeling clay, making a small "pond' about 1" in depth and fill with diluted ferric chloride dilute at least 5o,5o with distilled water. A slow etch is a good etch. Too fast and you get bubble trails and eroded surfaces. I put a light on my etch tank one time to speed the etch. It looked good after I sanded it back up to 400 finish and re etched SLOWER. About 70 to 78 degrees is a good temp in my opinon. Back to the logo. I let logos set about ten min. again testing your method on a scrap of the same hardness is VERY GOOD ADVICE. For full blade etch I suspend the blade In a tank made from 4" pvc and a wooden holder to keep it from tipping. Wear your glasses and keep the tank on the foor if it tips it won't spill in your face. Back to etching the Blade after 1min. pull it out and check for "shiny" spots, the shiny spots are some contamination on the blade and the blade will have to be recleaned before continuing. If you see no shiny spots. I clean the oxide off with a scotchbrite pad. and put back in the etch fro 5min. and pull out and repeat until the desiresd degree of etch is reached. Maybe 20min. altogether. I get better reults this way then leaving it in the etch 2omin. straight. When I reach the degree of etch I like I scotchbrite and rinse in baking soda, then TSP then Baking soda then Tsp. I don't get residual rust with the multi-bath rinse. a little oil after this process is beneficial also. This is the methods I've adopted after reading Wayne Goddard and Jim Hirsoulsas methods
If God did not intend for us to eat animals. Why did he make them out of meat?
