- Sep 20, 2014
Now is your opportunity to pick your color hardware and titanium handle on the coveted and extremely limited SM-100 Stinger by Ferrum Forge. Make this piece of history truly your own! All you have to do is place your preorder and then email info@btacblades.com what your anodization you want your handles as well as hardware color preference. Good luck! Supplies extremely limited!
http://btacblades.com/collections/ferrum-forge/products/ferrum-forge-sm-100-stinger
*Pre-Order, shipping approximately in January 2016
$975
The Stinger model marks a revolution on how we think about knives and what can be utilized for what can be considered best in class materials. Ferrum Forge has mastered the utilization of best in class materials and here is a rare and difficult to forge SM-100 blade which is a nickel-titanium alloy. Previously only used on one-off custom knives, Ferrum Forge has been part of the pioneering effort to promote this material for use in blades. The Stinger is the first knife model to utilize SM-100 in a production run which is limited to 100 knives.
Ferrum Forge's standard Stinger knives have a tumbled titanium frame lock handle with a blue anodized pivot and pocket clip. Blade color will vary from knife to knife. As with other Ferrum Forge Knife Works knives, the Stinger is outfitted with a steel lock insert/internal overtravel arrestor, Hoback Rolling Detent, and caged thrust bearings which all attribute to a smooth, fast dependable knife.
SPECIFICATIONS
Overall Length: 7.33"
Blade Length: 3.30"
Blade Material: SM-100
Blade Style: Drop Point
Blade Grind: Flat
Finish: Spectrum
Edge Type: Plain
Handle Length: 4.03"
Handle Material: Titanium
Color: Gray
User: Right Hand
Pocket Clip: Tip-Up
Action: Manual, Flipper
Lock Type: Frame Lock
$975
SPECIFICATIONS
Blade Length: 3.30"
Blade Grind: Flat
Finish: Spectrum
Edge Type: Plain
Color: Gray
User: Right Hand
Pocket Clip: Tip-Up
