- Jul 23, 2015
I've made a handful of folders and am currently playing with framelock flippers. Well I want them to flip but they just don't want to. I am working on better machining and setting detents. I have read that you want a strong detent to get them to flip.
I am using bearings from alpha and 1/16" stainless detents. This current one has smooth action but the detent is "rough" as it drags across the tang. I know the detent is slowing the blade down. I also know that the detent isn't strong enough. It will flip with wrist action, and also if I put pressure on the lock at with a little silicone spray on the blade to slick up the detent track.
I tried to use lapping grease on the detent ball and work the action back and forth. It didn't help much. What kind of tricks do you folder guys use to smooth out the action and "break in" the bearings or all the other pivot assemblies?
Do you mill a gradual detent ramp in the blade with a rotary table?
I have a mill and rotary table but I really suck at using them both. I do not have a surface grinder yet, all surfaces are done using a disc.
It's only a prototype that I've been carrying for a couple days now, and I know where my mistakes are, just searching for some hints to help break in the future ones I make.
Oh and one last thing, do you stake or peen the stop pin in or do you just let it float?
First ever frame lock
That one has flaws that effect the function so it stays with me for torture testing.
This one below I started messing with today, I waterjetted a few different blade profiles to expirament. I am waterjetting the frames and blades and then fitting the frames and blades to one another in matched sets. Each one is a little different.
