FFBM? what the heck did I just buy????
LVC...be sure to post some pics bro, you're going to dig this knife man. She is one fat a$$ mistress! Lots of heft and girth!! :D
OldPhysics:
A new FFFBM is popping up at BCS now...a Leprechaun Fattie.
That's lovely green linen handles -- standard or magnum.
Today 05:42 PM
Mag green linen? I thought Skunk just had the standard grips?
You guys have got me really wanting one of the freaking sage FFBMs. Why I would need it I don't know, but I am still loving it. Maybe someone can bring one to Blade so I can see it in person. :D
strange stuff... the ffbm is slighly longer, has a slightly smaller choil, and is slightly taller due to the more pronounced swag back....
I'll take pictures of it and weigh it and what nots' tommorow. It's not quite as heavy as I would have liked, but its definitely heavier and more stout, and more forward weighted. The lefbm does much better at being a "knife" and the ffbm does much better at being an axe. the tip of the ffbm is much stouter, the taper being about half as long as it is on the lefbm. The taper on the lefbm also being rounded, removing even more metal from the forward section.
Keep in mind, I'm the guy who wants 3/4" to 1" thick 18" ang khola's, so heavy to me is only reletive to the heaviest thing I've handled - wich is my 30" 5lb something oz sher ang khola.
now if I could get this thing in 1/2" thick - then we'd be getting somewhere ;)
I'll bring one for you to check out. Remind me after we're there. :D
It's not that big
(lefbm, ffbm, 18" ang khola (hi), 30" ang khola (hi))
attachment.php
attachment.php
attachment.php
attachment.php
But it is heavier, with thinner handles, and that makes me happy :D
lefbm vs. ffbm:
(in lefbm / ffbm format)
stock thickness at ricasso -
.310" / .304"
thickness at center of spine -
.280" / .304"
thickness at beginning of edge taper (measured at same distance from tip on both, based on distance of ffbm) -
.272" / .304"
Thickness at tip (at the ridge where the cutting edge bevel begins) -
.105" / .135"
Thickness edge near ricass (at the ridge where the cutting bevel begins) -
.055" / .087"
point of greatest over all thickness of handle slabs (mag vs. standard) -
1.065" / .830"
Choil size (from edge of talon hole in line with the edge to the start of the cutting edge) -
1 15/16" / 1 14/16
Overal length -
16.25" / 16.50"
weight -
16lb 12.9oz / 1lb 15.8oz
so, the ffbm isn't thicker in stock thickness at the handle, but it maintains its overal stock thickness from from the to back where as the lefbm tapers noticably from the ricasso to the tip, and has a the full flat grind with a thinner edge. Because of the thicker stock thickness in the handle and the mag handles and the full flat etc etc, the lefbm does much better at feeling like a fast chopper, something thats easier to use for regular cutting tasks without instantly weighing you down, and it feels like it would absorb shock better.
And then the ffbm feels like more of a chopper, with a much more "solid" feeling handle. Solid like a crowbar though, it feels like it would reverberate more because of how solid and heavy it feels. I doubt that there is much of a difference as far as actual transmission of shock and vibration in actual use, thats just how it feels. The ffbm I have is also a 1/4" longer then the lefbm I have. weird.
Overall I instantly prefer the ffbm just because I wanted the fbm to be as heavy as possible when I got it. Oddly enough, the 18" ang khola with its stock thickness of (at ricasso) .429" actually weighs .2 oz less then the ffbm. even at almost a half inch thick, it loses most of its weight by not having a full tang handle at its stock thickness like the battle mistresses have. It also throws its weight farther forward by losing its weight in the rear. For reference, the 30" ang khola weighs 5lbs 4.2oz.
