- Jun 13, 2007
I have very limited time to actually work on my knife. Unfortunately that meant grinding in bad lighting last night.
Anyway, on a flat ground blade, what do you do if you grind into the spine? Meaning the blade is a bit thinner than the full tang. I could thin the tang, but lack decent equipment. I've tried before and ended up with a non-flat tang that I ended up chasing forever trying to even out.
Feels like it would almost be easier to taper the tang than try and thin it. Is tapering really that hard?
I also considered rounding the spine to try to blend it into the full width tang, I'm just not seeing an easy transition. It's fairly abrupt into the ricosso/bolster area.
Any ideas?
Any ideas?
