The liner I use is a paper fiber, maybe some plastic mixed in. You can really use anything that will hold up. I have one on the bench with a titanium liner, just seems like a good idea with carbon fiber. Make sure it wont soak up moisture and will stick to glue and you should be ok
be carefull with plastics, most epoxy will not stick very well. If you have pins or bolts you will be fine. The nice thing about fiber spacers is they will form a bit to fill any gaps.
