- Oct 16, 2010
Gentlemen:
For your consideration is this hidden tang Field Master in 1095/stabilized fiddleback Bastogne Walnut. The tang extends 3/4 of the way into the handle and is set with G/flex marine grade epoxy and a 1/16" stainless pin. The flat ground blade was hand rubbed to 1200 grit and etched to reveal a vivid hamon. The solder joint is perfectly executed with no pinholes. In order to bring out the brashness of the fiddleback, the handle was hand rubbed to 2500 grit and waxed rather than darkening the figure with a buffer. This is a large hunter, designed for the biggest game like elk, bear, moose, water buffalo. I hope you like it! The first "I'll take it," PM, or email gets it. $385 delivered CONUS. Paypal preferred to tsteingass@yahoo.com. Thanks for viewing and all comments are welcome.
V/R,
TK
.170" 1095 Stock
HT to Rc 60-61
9 1/4" OAL
4 1/2" Flat ground blade
Vivid hamon
Soldered stainless guard
Black G-10/stainless spacers
Rounded spine with thumb serrations
Stabilized fiddleback bastogne walnut
RH vertical sheath
V/R,
TK
.170" 1095 Stock
HT to Rc 60-61
9 1/4" OAL
Vivid hamon
RH vertical sheath
