So a consensus for a hunting/outdoor fixed bladed knife that uses a high-quality steel - the new term may be "premium steel??" - where the blade will have hard, but not abusive, use is 15 degrees DPS? And while such steels are capable of finer edges, such edges may have durability issues were knife use to include more than slicing?
What is EPA??There's diamond stones for EPA. I use 'm.
What type of steel? And what are you cutting resulting in chipping?For me, 15 per side chips too easily. Just my experience.
This.
440A requires a steeper bevel or microbevel as well.
I've posted these elsewhere, but here they are for reference:
Edge Angles:
Comparison of a few knives all sharpened to 30-inclusive except the red box-cutter blade that is <20:
Like Joe Calton mentioned in his review, it is VERY important to discuss not just angle but THICKNESS. Axes and wood-chippers and lawn-mowers and even razor-blades commonly use a 30-inclusive edge angle, but apex-diameter (how refined that 30-inclusive is) and thickness behind the edge determine its utility, not that angle. An axe is not normally ground to <1 micron apex diameter at high grit, there is no need for that level of precision on such a tool, but it DOES require a thickness behind the edge suitable to support that edge. When Joe mentions 0.020" thick for chopping bone, that is roughly comparable to the green blade in the diagram above. 0.020" is common on many folding knives and small fixed blades.
The yellow blade is a slicer measured at 0.005" behind the edge when that diagram was made, MUCH too thin for most chopping tasks, but stronger near the apex than the box-cutter yet thinner than the box-cutter for a significant region behind the apex.
Discussing suitability of geometry without discussing behind-the-edge thickness is ignoring the most significant aspect of that geometry.
