Well the holes and pins makes sense. This is my first folder so I have made one out of 1/8" Aluminum because it was fast and easy to do. The blade wobbles a little but if I stick a single a sheet of paper in the front of the lug the lock up is tight so I'll just be more careful on the actual steel. I am thinking of using the aluminum parts as guides. I can magic marker the aluminum and file the steel down until I get a match.
I'm a hobby-ist so milling machinces, etc are out. I am making jigs to do a lot of the work. To make the nail nick I am thinking a router whose shaft is placed in a guide (steel angle) slots in this guide allow the cutter to move down and side to side- to make the nick.
At first I thought ALL the edges had to be perfect but when you think about it the lock needs to be correct but the top of the blade, scales, lever, etc- after everything functions- they can all be filed smooth to some extent. I was going to use a 3/16" bronze bushing on the idea it would be slightly thicker than the blade and give flawless function but I read you will still mess things up if you peen the blade rivet too hard as it then distorts the bushing, so...now I am thinking about a steel shim paper thin that gets pulled out after the rivet is peened.
It's a learning experience- just trying to shorten the curve as much as possible.
