- Dec 24, 2014
So I'm building a knife as a gift for a neighbor. Its a 7" fillet made from .07 Aeb-L. As there is much better flex in this one from my last fillet I attempted, I am worried about the handle strength. This was the last bit of .07 steel I had, so I had to make it into a hidden tang. My worry is, since it is Aeb-L, I cant just anneal the tang and drill for a corby after the handle is on, so I'm looking for ideas to make the handle strong enough to handle the blade flex.
I was thinking of cutting the block into scales and then channeling each side for the tang, but I'm not sure how the two pieces will blend with simple epoxy....
As I had this in my mind from the start, I luckily drilled 2 holes prior to HT just in case.
Any help would be great.
