I am just starting to make Knives, We have tried 01 3/32 and it appears to not have the flex. I have a piece of old Handsaw that I think may be to thin. How about a old Bandsaw blade? I really not know what to use.
Go ahead and try that handsaw material, you have nothing to lose. Keep the steel cool as you grind it. Don't forget to browse through the beginner's thread.
Another maker in here uses CPM154, as do I. I leave the handle the full thickness(.093), and thin out the spine to .060. After HT the blade has what I would consider a "medium" flex. Then again too the blades I make are fairly large for skinning 50lb+ amberjacks so if you make a shorter blade you might want to go thinner.
For most of my small filet knives I use 1/16" 440C.Will give you alot of flex and good corrosion resistance. Most of mine are 6-7" of blade and 11-12" overall usually about 1/2" wide.
Stan
