Filling in a large void in handle wood
I got some cool burly scales that have both a tapered section and a large void on the backside that I would like to fill in order to use on a knife handle. I looked at alumilite casting but it seems to require a pressure pot and is too much cost and effort just for this one set of scales.
I've seen tutorials online for people making homemade micarta/mycarta with epoxy and material just simply squeezed between two pieces of wax paper lined plywood in c-clamps. I was thinking of just making a little box lined with wax paper and then pouring some epoxy in there on the wood. I have a few epoxy dyes that I could use instead of leaving it clear, though clear might look interesting? I would sand and use a wire brush to clean up any wax from the wood first so hopefully the epoxy would adhere okay.
The backside with the epoxy fill would then get glued to a liner and used on a personal knife, just something for myself so not a big deal other than losing time and effort and a nice piece of wood if an abject failure. The biggest downside might be bubbles in the epoxy, but I could use a hair dryer to pop the bubbles with heat like when making mosaic pins.
Is there a fatal flaw to my idea that I'm not seeing?
Pics of the scales in question (cocobolo):
I’ve used super glue and saw dust over multiple layer build up to fill voids. Hard to tell from the photo how large the void.
maybe send it off to have the casting thing done? i know its not fast but there are guys out there doin it (i have a few blocks i think im going to get done )
Are you talking about that huge divot in the scales? I have seen guys fill small voids and knot holes and it looks cool. I think that what you have is beyond that . I would not consider that a void, it’s missing a large section. I say cut it up and make a stacked handle out of it. That’s just such a large surface area with no wood sides to hold the epoxy in place. I feal like it would have a tendency to want to pop off as the wood moves from humidy and temp change.
