Yeah it is, im wondering the same thingI don t understand how that can happen ? Work rest is 90 degree to platen behind belt ?
I think I know where you make mistake ......You *lessen* the angle too much and you grind more toward spineThat is correct, I set it at a 45 degree angle to start, grind down to the scribe lines, and then lessen the angle on the jig 10 degrees and then grind to the scribe lines again, and complete this process over and over. I usually run out of jig angle before im able to meet the spine with the bevel
I do! I start at 45, grind to scribe, lessen it 10 degrees, color bevel edge with sharpie, grind until sharpie is gone, lessen angle again and repeat the process.I think I know where you make mistake ......You *lessen* the angle too much and you grind more toward spineUse permanent marker on bevels after ever change of angle so you can see where you remove steel
Do you have picture where we can see spine of knife ?I don t understand how that can happen ? Work rest is 90 degree to platen behind belt ?
Your right its not flat but that is from my lack of free grinding skills lol. I could only take it so far with the jig so the rest was done by free handing it and I was trying to hog off material to lessen the behind edge material so its not perfect.Maybe your platen is dished out? The grind does not look very flat - just judging by the photos, hard to tell.
FORGET that 10 degrees .................Just use Sharpie .And move that adjusting bolts very little .I do! I start at 45, grind to scribe, lessen it 10 degrees, color bevel edge with sharpie, grind until sharpie is gone, lessen angle again and repeat the process.
CORRECTION I see what your saying. Alright ill give it a try! I think today im gonna try making a knew jig that has only one bolt. Just gotta find a tap set that wont strip out on me....FORGET that 10 degrees .................Just use Sharpie .And move that adjusting bolts very little .
Thats what ive been trying to do! Taking your advice from another post.Regardless of how you shape the bade, the main thing you want is when the bevels are done the edge is almost sharp. It won't cut paper, but feels sharp to the finger. This is when you start the final edge.
Work rest is not adjustable ? If not use longer angle iron so bevels to be whole supported . Use bigger size of angle iron if you have ? And pay attention where you apply pressure, you can easy raise bottom side of jig if you don t pay attention ..... and you will chasing the tailCORRECTION I see what your saying. Alright ill give it a try! I think today im gonna try making a knew jig that has only one bolt. Just gotta find a tap set that wont strip out on me....
Can you explain this to me ? Why jig don t allow me to follow the edge ? And how you come to conclusion that JIG are not good at getting precise angle ? I use them for years and what I learn is complete opposite of what you write , my friend ? And don't again take this as some kind of aggressive behavior on my partLet's talk numbers:
The bevel angle on most knives is around 4° to 7°. A .10" thick knife with a 1.5" height has an "edge" angle of 4°.
If you want the secondary bevel (cutting edge) to be 15 degrees per side, it should make a edge line about .020-.030" high. (Assuming the edge is .010" thick at .020" from the edge it would be 30°.)
All this is why I hate jigs. They may or may not be ny good at getting precise angles. They don't allow you to follow the edge.
look at thickness of spine on handle and look thickness of spine of blade
Fredy my friend , I make so far over a hundred kitchen knives from 1.5mm thick steel . Even full flat ! And I don t give **** about any angle . I just adjust work rest angle as I grind .................. till I get what I wantOr why not do your initial “45s" until you have basically a sharp edge and then start dropping the angle on the jig?
I also think that chef knifes are not the easiest on the jig as they have very shallow/low angles.
You could also try the push stick method. Basically take your knifes that have too thick BTE thickness and apply pressure with the stick on the edge until you start to see your wide secondary edge getting narrower. This will mean that you are effectively thining the edge.
Stacy advised same .............that is VERY bad advice ..........................to work it depend of thickness of steel and how high you will grind bevels .Or why not do your initial “45s" until you have basically a sharp edge and then start dropping the angle on the jig?
Congrats on that last one, I didn't say it's not possible, i just think it's not easy, especially if OP still doesn't grasp if he is grinding towards the edge or spine..Fredy my friend , I make so far over a hundred kitchen knives from 1.5mm thick steel . Even full flat ! And I don t give **** about any angle . I just adjust work rest angle as I grind .................. till I get what I want
Last one , almost to sharp edge ...................1.5 mm
