You may not be taking enough off at each grit after 60. It's a big step from 60 to 220, so you might try some 120's or 150's.
Spray some WD40 on the back of the belt so it slides over the platen easier, if you are flat grinding. Then make sure you are well into the grinder with your body, elbows locked to your sides That will take the bobble out of things and keep your grind lines straight.
If your belts are clogging really badly, they may be cheap belts and you'll have to upgrade. Grabbing is usually the sign of a used up belt when we try to get the last bit of performance out of the belt but already have. You hit a point where you have to put a new one on and throw away the old belt. We all hate to do that, because belts can be a sizeable investment.
The investnebt has to be contrasted against a messed up grind line that you have to spend more time fixing, or the possibility of injury and lost time from making as a result.
In my experience, when the belt starts to grab, it goes in the trash, period. I'll keep used up belts around for profiling or cleaning up a profile, but that's it.
Should you try 36 grit, they eat steel in a hurry. They also leave deep grind lines that you will have to grind out with another grit. Go easy on 36's. Leave lots of room to go at the blade with other grits. If you profile with a 36, always clean it up with a much finer grit before HT. The 36 can leave a deep enough grind line to cause a stress riser that results in a broken blade. Treat them with respect. A 36 will eat skin awfully fast, too, should your work slip.
If you are grinding to 600 prior to HT, you may be wasting some time, too. Depending on the steel you may have to drop back quite a bit befire you can break through the discoloration from HT. Watch your heat when using 400 and 600 grit belts on finsihed blades. The finer the grit, the faster the heat build up.
Perhaps the solution to your problem is in there somewhere.
Gene
