J,
I always grind the taper right after profiling the blade to shape, pre heat treat.
Stop the distal taper at the plunge lines.
The cutting ability of a blade is dictated by steel selection, geometry and edge finish. Geometry includes, steel thickness, blade shape and grind profile. Choose the thinnest steel stock possible and accompanying grind profile, that matches the work load for that knife. The thinner the spine, the greater the opportunity of producing a superior cutting edge. If you think of the cutting edge itself as basically none existent; refined to the point of not being there and the area behind that as supporting that edge, as well as hindering the cutting ability, then you can get a better idea of why the geometry counts so much. You hear the term, "thickness behind the edge" it's talking about grind profile. The thinner that measurement can be made and still have a knife that will hold up to the work, means you have produced the best knife for that work. Grinding distal taper into a blade allows for a thinner grind profile forward on the blade. Thinner behind the edge. There are new steels being produced that are specific to making blades and offer characteristics that we knife makers take advantage of in producing superior cutting tools.
Please excuse the long windedness to your straight forward question, Fred
