You will need a tight progression up to at least a 15k stone , before moving on to a 30k strop. If you already have that covered , then what kind of steels are you dealing with?
i use the lansky system, i was using fairly light pressure on the stone, but its possible i didnt spend long enough going from the coarser stones to finer stones and lined myself up for failure there, i'l go back to 1000 grit and start my way back up, i hit it again with the 2000 grit and the scratches are much more fine so maybe if i just go and do 5-6 passes with light pressure then 10 with just weight of stone i can get them all gone.
alright, i'll go back to the super fine stones and work at getting every scratch gone, my max grit is 2000 on a stone so will that be plenty?
I've noticed the bar compounds I've used (from Ryobi & Sears) are much easier to apply on a denim/fabric strop. The fabric 'scrubs' the compound from the stick much more agressively, and holds it very well, which contrasts with trying to do the same on a leather strop. I had previously sanded my leather strops, to get them to accept the bar compound a bit more easily; but with use, the surface smooths out again, and needs some re-sanding when re-applying fresh compound.
The bonus with fabric/denim is, I've also liked how these strops have perfomed on my edges, which I assume is due in part to it's ability to better hold the compound, at least, if not due to other factors as well (such as reduced compressibility & firmness on a hard backing). They work a LOT more aggressively with a given compound, than anything I've seen on leather. I stopped being concerned about burrs completely, after switching to fabric strops on hard backing.
I'm tinkering with some of my older leather-on-oak strops this morning, a couple of which I cleaned up a while back and they've currently no compound on them. As bare-leather strops in this state, I'm beginning to like them more without compound, AFTER using my denim strop with compound. Just the little bit of additional burnishing afforded by the bare leather seems to add just a little more silky pop to edges (I'm testing by slicing phonebook pages), after using compound on the other strop.
David
David
The above is very similar to my sentiments but with the compound applied to paper. The paste honing compounds actually do not perform as well on paper as they do on leather in my experience, so the bar/block types are preferable - if they need to be tamed for steel type or cosmetic advantage, a drop or two of mineral oil is all that is needed.
Used with paper over a Washboard or on the coarse side of a stone, the hard block compounds actually act to compress the paper even more. Between the binder infiltrating the fibers, and the added force of the harder blocks when being applied, the surface is very flat and dense compared to the leather strops I've owned. The stuff I make for use with my kit is so hard it doesn't even really attract dust or dirt - if it does get 'contaminated' it be cleaned off by simply brushing at it.
Not giving up much going from a soft waterstone to that sort of strop, but is a different application compared to the usual leather strop - a few light swipes at the end of a fine stone.
