Finishing a Yanagiba
Daniel Fairly Knives
Full Time Knifemaker
Moderator
I just came across this video and thought you guys might enjoy it. This guy has some serious control at the grinder!
[video=youtube_share;iCtx8VYxUK4]http://youtu.be/iCtx8VYxUK4[/video]
Those wheels are called kaiten-toshi (rotating water stones). They run from small ones at 24" to big ones at 60". Most are 1 meter, about 40".
It is still a good year away from completion, but I will have a build project in the engineering stages on making a modern version of one for knife shops. Stay tuned in 2013.
More grinder porn:
http://video.search.yahoo.com/video...ono-+Sharpening+knives+on+a+large+water-stone
That was a very cool video. Those giant wheels remove some serious metal. I would love to get me one of those if space allowed.
Those who have been following my ramblings on this build have heard several variations.
Originally I was making a large (30-40") contact wheel, and the grinder would be similar in operation to most three wheel grinders.
Then I was leaning on a two wheel system with the drive wheel being the small wheel.
Then a direct drive main wheel on a two wheel system.
All these required building expensive and close tolerance parts that needed to be very heavy duty. While not completely abandoned, these were not the best options.
Then I hit upon using something already made to turn, handle lots of force, was adjustable, cheap, and readily available to anyone, anywhere.
I came up with using a front wheel drive auto or truck wheel and the mounting hardware. Think about it, it has the steering arm, which can become the tracking, the upper and lower mounting arms to bolt to the frame, the arms also move up and down to allow tension adjustment and belt change, a CV joint to drive it, and a hard rubberized serrated or smooth contact wheel called a tire. A plus is that it is fairly water-resistant. There are common tire sizes available from 4" to 6" tread width in diameters from 20-30". Larger diameter tires may be possible.
If you want to drive it from a 6" drive wheel, just remove the CV joints.
My current direction is for a standard junk yard build with the thinnest and largest tire size that I can find reasonably. I would love a 145/90/24 but that isn't a likely find. A 15-16" wheel will give a 24" diameter. A 20" wheel will get around 30"", but finding a thin tire for a 20" rim isn't likely.
If any of you gear-heads have info on the narrowest and highest profile tire that will fit a standard rim size, and the car type it will fit, let me know by PM or email.
I have been aware of his build since he did it. There are several others out there, all pretty similar. The problem is that the wheel cost him well over $1000 .
IIRC, he had about $3K in his grinder.
I think I can build the whole rig for $1K, including the motor.
This is going to be fun! :cool: ...staying tuned in.
