Finishing G-11 Garolite
I have a handle that I am in process of finishing that is made of a Jade Green G-11 Garolite. My question is, at lower grits, it sands nice and clean but now that I am up in the higher grits (1000) it seems as if it picks up the color of the sandpaper and gets a bit darker? Any ideas of how to keep it nice and clean? Maybe sand it underwater? And in case you are wondering, I do use a respirator mask while working w/this material since it is a epoxy based phenolic. Thanks, Don
I've found that G-10 and G-11 will typically lighten as I sand them at rough grits. As you increase the grit, less light is scattered from the surface of the material and the color seems to deepen a bit. I always treat my sanded G-10/11 with a short bath in mineral oil after sanding. This has the advantage of highlighting any previously-missed blemishes, which can then be sanded out.
TedP
TedP
One of the stickies said to use dawn dish soap and clean the scale, then spray it with WD-40, then use dish soap again to clean and check for blemishes once you are done sanding a piece.
Sanding wet with very-watered-down dish soap has worked for me on "ivory" paper micarta. I believe the idea is just to keep the bits of silicon carbide (and metal if you're sanding across bolts like I was) suspended.
Thanks James, That makes a lot of sense to me because I am sanding across brass as well as the G-11. Thank you!
