- Jan 15, 2015
... proper edge on high vanadium knives? ...
proper is a bit subjective, but I would point out that the factory edge on my Spyderco Maxamet Native and S110V Para 2 were carbides exposed by buffing.
Does anyone have experience specifically with skinning? I tried to skin a hog with my spyderco sage because it was in my pocket at the time, but it had a fairly polished edge (6k, stropped with flitz polish) and didn't work as well as the cheap butcher knives lying around the skinning rack.They seemed to have coarse edges and the guy I was skinning with used a steel to bring the edge back a couple times (hog skin is quite tough).
I have a Spyderco Gayle Bradley that I want to set up for skinning. I'm thinking about putting either a 320 or 1000 grit edge on it with my shapton glass/suehiro waterstones. Does that sound right for a skinning knife? What do you guys do?
Do you think stropping with diamond paste after using japanese whetstones would do the trick, or would I need to use diamonds all the way through? I already have a 140 grit diamond plate, but my 320,1k,5k and 8k are all Japanese stones. I do have a couple leather strops loaded with 1 micron and 0.5 micron diamond paste. What equipment/procedure would you suggest for putting a proper edge on high vanadium knives? I would consider buying a high grit diamond plate for finishing the edge. Would a DMT Dia-sharp EF or EEF do it?
If you don’t have coarse diamond or CBN, it is OK to grind bevels of your wear-resistant blade with a coarse silicon carbide abrasive; however, setting the edge apex and honing must be done with diamonds/CBN for the lasting sharp edge. Honing the wear-resistant edge with conventional compounds, including fine ceramic hones, is the main cause of them dulling early – if you use them on your high-end knife, it may perform even worse than a mainstream knife.
We've sharpened premium knife steels both ways, testing the sharpness and edge stability to rolling - and the conclusion is that for the best results, from the #1000 and finer must be diamonds or CBN.
Sorry to say that, but by my experience, what you have is not adequate for sharpening wear-resistant blades.
Moreover, for the best outcome one needs some angle-controlled sharpening method, rather than sharpening freehand on diamond plates.
Todd is the most comprehensive source of SEM images, available on his website http://scienceofsharp.com. I think Todd knows more than anyone about knife and razor sharpening, and I've learned a lot by reading his comments.
If you re-read Todd's description to the MAXAMET SEM images, he set the edge apex on #1200 diamonds, and honed with 1-micron diamonds.
We do it similarly, but somewhat differently in that, having set the apex on #1000 CBN, we then hone wear-resistant knives with a progression of diamonds from 10-microns to 0.25 microns. E.g. see our detailed protocol in the video
...Separate question, I am still confused by the maxamet article. Why does he claim that finishing on a #8000 Shapton glass (resin bound ceramic, I am pretty sure), increases edge aggression and retention?
The 8k Shapton glass (with a bit of slurry) does not cut the carbides, only the matrix around them, duplicating the factory edge, which has excellent slicing aggression.
Edge aggression and retention is reduced with a 8k shapton for skinning, especially with a high vanadium super steel at high hardness.Thanks, that is useful. I really enjoy sharpening freehand and forming a smoothly radiused convex edge, so I probably won't buy an angle guide system but I may pick up an EF and an EEF DMT dia-sharp plate at some point. That would get me #1200/9 micron and #8000/3 micron diamond abrasives. After that I have the 1 and 0.5 micron diamond paste. Do you think that would have the desired effect?
Reduced relative to what? an 8k diamond plate?
To a lower grit CBN/Diamond in the 400-1000grit range.
Also there are more stones available in diamond/cbn than just "plates" that offer more features to finish and cutting speed.
Metallic, resin, and vitrified bonded diamond/CBN.
That's the way to go - you will see a drastic performance improvement in your premium knives.
On diamonds (or CBN) we can sharpen wear-resistant steels with little pressure, as compared to stones, minimizing that "tired edge" with poor retention that we get off the stones.
The steel matrix around the vanadium carbides does not get eroded, and the carbides themselves are shaped sharp towards the edge.
Without diamonds we get on premium knives just a "working edge", while with diamonds we put on them a lasting shaving edge.
Ahh that makes sense. Do you have any recommendations for sharpening products to check out? I am trying to get really good at freehand sharpening so I've been looking at the DMT dia-sharp continuous diamond plates. Are there alternatives that you think I should look at? Keep in mind I do not have any guided system or motorized grinding hardware.
I also freehand.
I recommend the venev diamond resin stones to start with. They are better than the DMT plates in finishing and longevity.
I'm more partial to other stones but the venevs are more affordable.
Yup, those are the ones I'm looking at. Thanks!Regarding Venev stones, make sure you get ones with OCB resin.
I just read the report Edge Rolling in High Vanadium Knives Sharpened with Aluminium Oxide versus CBN/Diamond and I have a question. Did you do any testing of mixing abrasives types, i.e. shaping on aluminum oxide and finishing on 3 micron diamond, or shaping on cBN and finishing with the Tormek compound? If not would you consider doing this for Elmax where the effect was most dramatic?
We can tell without exhaustive testing that an edge apexed with conventional abrasives and honed with diamonds will have properties of all-diamond sharpened edge, while the edge apexed with diamonds/CBN but honed with conventional compounds like Totmek honing paste will have properties of all-Al2O3 sharpened.
This is because weakening of the steel matrix happens during fine honing, not bevelling.
