- Mar 13, 2018
Ive recently taken a dive down the rabbit-hole of buffing/finishing/rouge/polish/etc, and now I have more questions than answers.
I have been just doing hand-sanded finishes. For my hamons, Ive been taking them to 1000 grit and then etching in 1:4 FC/distilled water for about 5-10 cycles (1 minute down to 10 second dips, polishing with flitz on a paper towel in between). Ive been somewhat unhappy with how the hamons have turned out - I get more of a blurry grey line and not much ashi. 1080/1084. Im honestly kinda done with hamons at this point.
My question is, for a full flat grind or a partial flat grind (leaving some forge scale on the spine), do I need anything other than sandpaper and elbow grease? Is there any point in buying a buffing machine and a bunch of wheels and compounds? Would that eliminate the tedium of hand sanding or significantly reduce the hand sanding?
Also, how many of you use your buffing machine for handle work? Again, I just hand sand my handles up to 400 or 600 grit and then use tru-oil, OOOO steel wheel in between coats, and buffing with wax after 3-4 coats of oil. Im pretty happy with how they turn out, but is there any role for a buffing wheel?
How would I finish san mai, if I were to buy a billet and make a stock removal knife with it? Can I get by with my same hand-sanding and etching process that I used for my (admittedly poor) hamons?
