I went to a Hammerin at Ron Claiborns' house a few yrs ago. A smith put on a display on how to hand finish a 12" Bowie blade in 30 minutes. Everone doubted him....that is..until it was finished in under 30 minutes. He had built a jig that held a 1/4 sheet sander, replaced the soft sponge rubber with a harder pc and mounted the whole thing upside down in two piece plywood clamp affair. The edges of the new rubber platten were square or very slightly beveled so that he could ease up to his plunge cut. He started at 220 and worked each side for about 3-4 minutes, then moved on to finer grit. I think he stopped at 1000. He then turned off electric to sander, backed down grit to 4-500 and pulled blade over the rubber platten, remembering not to go back and forth but drawing backwards only to alleviate j hooks. It was quite incredible, it worked like a charm and no one could tell the difference. Try it..you'll like it.
