America has reached 250 years, and I am grateful to be here, in the best country in the world. Thank every one of you who helps make this country a better place, those who have gone before and risked it all, and those who've paid the ultimate price to make the United States what we are today.
Philpso said:JT
Since the pot is connected to lethal voltages, make sure that you use one that has a plastic shaft to avoid electrocuting yourself.
Phil
Nickey........glad to see your full-time job hasn't spoiled your unique sense of humor.NickWheeler said:I know Finley, and I'm not a bit surprised to hear that that bastard did it again.![]()
B Finnigan said:With enough amperage either AC or DC can ruin your day if it travels through any vital organ(s).
It only takes a few thousanths of an Amp of current flowing through certain parts of the human body to cause death.
I agree Phil and you are talking about in both cases ACI don't want to be a wet blanket or sound like the "Safety Nazi's" here at work but safety is no joke. Some of the stuff being proposed here is simply dangerous.
yes I understand this , this is why I asked and thought it better to have another diode in the neg line it was a question, I would rather see a full rectifier in there to be safer on the other side, what I don't understand is the other devices in there and what they will do to DC current and if they may cause the DC to convert back to AC with I agree could or can kill you.The latest circuit, with a single diode rectifier, will draw asymetrical currents from the supply at a frequency of 60 Hz. Since the current levels can be quite high, this alone may cause distortion of the voltage waveform and cause other equipment in the same house and neighboring houses to experience problems.
JTknives said:well i tuched the output to the motor while i was wireing it to the speed controler and i felt a tingle but nothing like when i was working for my dad and i was installing plugs in the wall and the power as not sapost to be on, well it was. now i have goten zaped by 110 quite a bunch and it does not bother me that much. from what i have read it is the amps that kill you but for it to do that you need to have somthing like 70-100 mila amps strait acros your heart to stop the muccles which are run by electrial pulles from your head. but for the most part electricty travils across the skin and not through the body. i have by axcadent shorted an ac welder through my body, ground in one hand and the welding clamp in the other. i hit the floor but was not hert.
I think if Finnigan mentioned in the first placeToxey said:Doesnt matter whether it is AC or DC,with enough voltage to pass thru the body,and enough amps behind it,you will die from either.
That is fact not fiction.
Car batteries do not have enough voltage to pass thru the body,a welder is getting close but not quite enough.
You can let your guard down with DC if you want,its your life you are gambling with.
this would not have been such a threadAC or DC,with enough voltage
Dan Gray said:lightening is high voltage with low amp's you don't have both, you burn or cook because of it heat if hit, it's not electrocution.
