Fire Piston Video!
I've finally made up a video on my Fire Piston! It shows how to make one from hardware store parts, and shows it being used.
Check it out!
It's not quite as easy as I make it sound, but anyone with reasonable machining / 'working with your hands' skills shouldn't have a problem. It's just very important that the system is 100% air tight. If anyone wants help building one, let me know.
Regards,
CanDo
Your welcome :)
By the way, if anyone has an account on metacafe, could you please rate the video? My others have done very well there, but this one is sort of dying for some reason....
Thanks for posting this! I have tried several times to make one from wood dowels, but couldn't get them to work. I have never seen one made from metal and never thought about it until now. This should be so much easier to do than a wood or plastic one!
Warren
That was outstanding CanDo. :thumbup:
I even felt like doing a shot of tequila, chased by a Dos Equis listening to the music! :D
That's an excellent tutorial on how to construct and use a fire piston. It looks easy enough that I might even try it!
Excellent video. Now I want to run out and make a fire piston! I am curious about how to remove the threads on the bolt though.
Thanks for the compliments, guys :)
Very nice. Did you grind the threads off the bolt?
Actually, I made the Fire Piston first, then reverse documented construction; the bolt shown in the beginning was the only one I had laying around after the piston was complete. The bolt I used was originally 6 inches long with 2 inches of threads, which I just cut off. A bolt with the threads all the way should work OK, but there might be a long term problem with the inside of the bore being scratched; if you use this kind of bolt, I'd recommend just grinding the threads off.
Sometime soon, I'll have dimensions of everything (of the parts, size of hole, etc.). The one thing I know for sure is that the total cost was under $5 - possibly free if your garage is well-stocked.
One other note is that some of the tubes for sale are smooth on the inside, and some aren't. Hold them up to the lights in the store, looking through the inside to make sure there aren't any burrs or anything. If there aren't any which are 100% (as was my case), spend a bit of time polishing the inside; I just 'chucked' a piece of a rag in a drill and soaked it with polish compound.
This design can work without lubricant, but - especially in the beginning - you should put a bit of lip balm, crisco, or spit on the o-ring. (I'd avoid light oils like wd-40 at the risk of creating a one-shot diesel gun).
Go very SLOW while cutting the groove for the o-ring, checking the fit frequently to make sure you don't go to far.
Good luck to anyone who tries it! If you haven't done a lot of this stuff, before, I'd recommend picking up an extra bolt and o-ring or two.
Warren
I had tried twice before using wood dowels and plastic; both were miserable failures. If I get access to some stationary tools (drill press and lathe), I'd love to make a Fire Piston out of some tropical hardwood.
