Evolute said:Lots of good points, here. But a few misconceptions need to be corrected.
Skammer,
1) The ferro rod, by itself, can be gently shaved to make a built in tinder, similar to what you'd have with a mag block, except less work. So, if you have a ferro rod, you always have emergency tinder as well as hot sparks. It's not a great way to go, but it sucks no worse than the mag block.
2) The fatwood-can-be-separated-from-the-rod vs. the-mag-firestarter-is-all-one-piece argument fails because (a) it is easy to make fatwood and a ferrocerium rod into a single unit, and (b) similar to the mag block, you could even buy one of the many single-unit items, such as this:
http://www.the-firestarter.com/
skammer said:... fatwood dose a few but eventually crumbles and dries out in your pocket over time. Its also not as durable as its wood. ...
Skam
tripletrash said:magneseum shavings are easily collected at home and used to make a start off point on an over saturated pj ball, wich will in theory burn longer than a lightly saturated ball. I put magneseum powder in a very small plastic bag with my sparklight tenders and they got a good little coating wich you can light without breaking them up any. I personaly like magneseum, and would definitly want it in an emergincy.
Craig_PHX said:Magnesium can work but other things work so much better, I refuse to bother with it. I'll keep my mini Bic lighter, Coghlan's Emergency Tinder, and a fat ferro rod pulled out of a Strike Force! That is what works for me.
YMMV!![]()
skammer said:I guess you learned it all in scout meetings. Lets hope the military learns from your scout meetings how its pilots are just carrying the wrong tool to start fires escape, evading and surviving in a crash.
what were they thinking![]()
Skam
YOu should call them.
Skam
As mentioned the tape can be used for a collector if it is impossible to get out of the wind.
