Thanks for the advice! I'll have to give it a try another day because unfortunately I'm running out of daylight.Make a fire lay from the twigs the smallest ones you can find. If you have some medium sized rocks make it on top of that so you can get underneath it. Then take the dry brush and make something similar to a bird's nest out of it. Not too tight to where it doesn't get airflow just a bundle with a depression in the center. Have some larger sticks in a pile at hand. Now shave magnesium into the the depression of your tinder bundle and then spark into that. When it gets going put it underneath your fire lay and when the twigs get going feed it the larger sticks being careful not to smother it. If that doesn't work ensure all your fire material is dry. Also I would personally collect a larger tinder bundle.
Sent from my SM-G920V using Tapatalk
