- Feb 1, 2007
Who is Ken Onion ??
oh that Cutlery Hall of Fame guy from da' island ?
vjb, does yours have the flat-head clip screws? As I understand it, that's a good indication its one of the first ones off the line.
I dunno. Claim 1a seems like it might in fact describe what is commonly described as "assisted opening".
I'm just curious. The use of a wire form spring as a "tension bar" on one design, and a "torsion bar" on another seems uncannily similar. Which is why I ask if there was any relationship between the inventors on record.
I do-know. Completely different. I've worked on patent cases.
When a pressure is applied to the thumb pin 16 in a direction illustrated by the arrow 48 away from the handle 14, a force is applied to the tension bar 38. When the force applied to the thumb pin 16 causes the associated force applied to the tension bar 38 to overcome the opposing force or tension of the tension bar 38 as applied by the walls of the arcuate recess 40, the knife blade 12 will be caused to pivot away from the handle 14 as the tension bar 38 moves along the arcuate recess 40.
I'd also note the Maxey patent was disclosed to the patent examiner in the application for the Onion patent. Since the patent issued the patent examiner concluded the Maxey patent did not anticipate the Onion patent.
So, does that mean the Onion patent was already being "filed" before the Maxey patent was introduced?
mike
Shecky, in the Maxey patent the blade pivots because the user is applying enough force to the thumb stud overcome the tension bar. The tension bar is not assisting the blade to open. Nothing in the language of the claim suggests that.
See, I'd disagree, referring back to the highlighted text in my last post.
